Salta al contenuto principale
Eco X Gear Gasket Replacement
Cosa ti serve
  1. Eco X Gear Gasket Replacement, Frame: passo 1, immagine 1 di 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Gasket Replacement: passo 2, immagine 1 di 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Gasket Replacement: passo 3, immagine 1 di 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Gasket Replacement: passo 4, immagine 1 di 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Gasket Replacement, Gasket: passo 5, immagine 1 di 1
    • Inspect the gasket around the perimeter of the frame. Remove the gasket using your fingers or needle nose pliers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 123
