Salta al contenuto principale
Eco X Gear Cone Replacement
Cosa ti serve
  1. Eco X Gear Cone Replacement, Frame: passo 1, immagine 1 di 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Cone Replacement: passo 2, immagine 1 di 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Cone Replacement: passo 3, immagine 1 di 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Cone Replacement: passo 4, immagine 1 di 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Cone Replacement, Cone: passo 5, immagine 1 di 1
    • Disconnect the wiring to improve accessibility to the cones.
  6. Eco X Gear Cone Replacement: passo 6, immagine 1 di 2 Eco X Gear Cone Replacement: passo 6, immagine 2 di 2
    • Remove the four screws which hold down the speaker. Then, pry up the speaker from the frame.
  7. Eco X Gear Cone Replacement: passo 7, immagine 1 di 1
    • To replace the cone, remove the existing one by peeling it off of the speaker with needle nose pliers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 142
