Salta al contenuto principale
Eclipse MTE28VGM Plastic Casing Replacement
Cosa ti serve
  1. Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: passo 1, immagine 1 di 3 Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: passo 1, immagine 2 di 3 Eclipse MTE28VGM Plastic Casing Replacement, Plastic Casing Replacement: passo 1, immagine 3 di 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Plastic Casing Replacement: passo 2, immagine 1 di 3 Eclipse MTE28VGM Plastic Casing Replacement: passo 2, immagine 2 di 3 Eclipse MTE28VGM Plastic Casing Replacement: passo 2, immagine 3 di 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Plastic Casing Replacement: passo 3, immagine 1 di 3 Eclipse MTE28VGM Plastic Casing Replacement: passo 3, immagine 2 di 3 Eclipse MTE28VGM Plastic Casing Replacement: passo 3, immagine 3 di 3
    • Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
    • Remove the motherboard from the front plastic cover and screen.
    • Install new plastic case following steps in reverse order
Conclusione
DELETED
Membro da: 10/13/16
252 Reputazione
2 Guide realizzate
IUPUI, Team 2-1, Harley Fall 2016 Membro di IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 166
