Salta al contenuto principale
Eclipse MTE28VGM Lens Cover Replacement
Cosa ti serve
  1. Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: passo 1, immagine 1 di 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: passo 1, immagine 2 di 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: passo 1, immagine 3 di 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Lens Cover Replacement: passo 2, immagine 1 di 3 Eclipse MTE28VGM Lens Cover Replacement: passo 2, immagine 2 di 3 Eclipse MTE28VGM Lens Cover Replacement: passo 2, immagine 3 di 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Lens Cover Replacement: passo 3, immagine 1 di 2 Eclipse MTE28VGM Lens Cover Replacement: passo 3, immagine 2 di 2
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
Conclusione
IUPUI, Team 2-1, Harley Fall 2016 Membro di IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 178
