Parti
Nessuna parte richiesta.
Remove the two screws on the bottom of the device with a Phillips head screwdriver.
  • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
  • Use a spudger to remove the plastic plate from the bottom of the player.
I can't budge the inner parts from its casing
tailoredvisions - Replica
Use the spudger to push the USB port on the bottom of the device inward.
  • Use the spudger to push the USB port on the bottom of the device inward.
  • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
  • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Aggiungi Commento
  • Freed from the internal space of the device, the LCD screen as well as the buttons will simply fall out of the face of the device. They can now easily be replaced.
Aggiungi Commento
Conclusione
James Walker
Membro da: 15/01/2015
343 Reputazione
2 Guide realizzate
USF Tampa, Team 1-4, Tanski Winter 2015 Membro di USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 741
