Salta al contenuto principale
Eclipse 180BL Touch Pad Replacement
Cosa ti serve
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: passo 1, immagine 1 di 1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: passo 2, immagine 1 di 3 Eclipse 180BL Touch Pad  Replacement: passo 2, immagine 2 di 3 Eclipse 180BL Touch Pad  Replacement: passo 2, immagine 3 di 3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 841
