Salta al contenuto principale
Eclipse 180BL Battery Replacement
Cosa ti serve
  1. Eclipse 180BL Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: passo 2, immagine 1 di 2 Eclipse 180BL Battery Replacement: passo 2, immagine 2 di 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: passo 3, immagine 1 di 3 Eclipse 180BL Battery Replacement: passo 3, immagine 2 di 3 Eclipse 180BL Battery Replacement: passo 3, immagine 3 di 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: passo 4, immagine 1 di 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,350
