Salta al contenuto principale
EchoMaster MRC-WLP43 Camera Replacement
Cosa ti serve
  1. EchoMaster MRC-WLP43 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Unscrew the two silver 1.4 mm Phillips #1 screws connecting the metal bar to the camera.
    • Don't lose your screws!
  2. EchoMaster MRC-WLP43 Camera Replacement: passo 2, immagine 1 di 1
    • Take the two tabs off the sides of the camera by unscrewing the four 1.2 mm Phillips #1 screws connected.
    • Don't loose your screws!
  3. EchoMaster MRC-WLP43 Camera Replacement: passo 3, immagine 1 di 2 EchoMaster MRC-WLP43 Camera Replacement: passo 3, immagine 2 di 2
    • When the screws are out, pop the two tabs off the sides.
    • Then you can pull off the back panel. You will then be left with the camera and wires. To install the new camera simply retrace these steps.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 309
