Salta al contenuto principale
Echo Dot 3 Mic/LEDs/Button Replacement
Cosa ti serve
  1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: passo 1, immagine 1 di 2 Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Turn your Dot around, so that the Barcode is facing up, and the buttons down.
  2. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": passo 2, immagine 1 di 2 Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $3.99
    • Using a Spudger remove the Lid.
    • There's Adhesive under the lid, so the best way to get it off, is to go all the way around with the Spudger
  3. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, immagine 1 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, immagine 2 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, immagine 3 di 3
    TR6 Torx Security Screwdriver
    $5.99
    • Unscrew the 4 T6 Torx screws using the Right Screwdriver
    • After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
  4. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, immagine 1 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, immagine 2 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, immagine 3 di 3
    • Unscrew the 3 T6 Torx screws,
    • and lift the flex cable connector.
    • After that, very carefully remove the PCB/Power supply (no idea).
  5. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: passo 5, immagine 1 di 2 Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: passo 5, immagine 2 di 2
    • Remove the 4 T6 Torx screws (2 different lengths!)
    • Slowly Remove the Middle part
    • Be very careful while removing the middle part, so that you don't damage the cable!
  6. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, immagine 1 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, immagine 2 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, immagine 3 di 3
    • Remove the 4 T6 Torx screws,
    • and lift the plastic to remove it.
  7. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, immagine 1 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, immagine 2 di 3 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, immagine 3 di 3
    • Simply flip the device to separate the:
    • Motherboard and
    • Buttons from each other.
Conclusione
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
Altre 2 persone hanno completato questa guida.
ashlynn
Membro da: 05/10/22
190 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 820
