Introduzione
Use this guide to replace the ignition coil in your Echo Chain Saw CS-590 (2019).
Although it's not necessary to remove the guide bar, it's highly recommended you do so to minimize any damage to the chain and to yourself.
Cosa ti serve
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to pull up and disconnect the spark plug boot.
Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
Four 24 mm-long screws
One 25 mm-long screw
Pull the handle toward the rear of the device to remove it.
Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
Push the guide bar towards the back of the device to create slack in the saw chain.
Pull the guide bar away from the device to separate the saw chain from the clutch drum.
Remove the guide bar.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
Pull the front hand guard toward the rear of the device to remove it.
Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
Pull the engine cover straight off the device to remove it.
Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
Use your fingers to reroute the spark plug cable from its slot in the fan cover.
Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
Altre 5 persone hanno completato questa guida.
2 Commenti
Useless. This shows nothing about having to put the sparkplug connection onto the coil which was sent WITHOUT
that connector.
Most of them have a self-tapping screw in the rubber cap and you just screw it onto the wire.
