Salta al contenuto principale
EasySMX ESM-9110 Backplate Replacement
Cosa ti serve
  1. EasySMX ESM-9110 Backplate Replacement, Handle Covers: passo 1, immagine 1 di 2 EasySMX ESM-9110 Backplate Replacement, Handle Covers: passo 1, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Backplate Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Backplate Replacement: passo 3, immagine 1 di 1
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, immagine 1 di 3 EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, immagine 2 di 3 EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
  5. EasySMX ESM-9110 Backplate Replacement: passo 5, immagine 1 di 1
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
  6. EasySMX ESM-9110 Backplate Replacement: passo 6, immagine 1 di 3 EasySMX ESM-9110 Backplate Replacement: passo 6, immagine 2 di 3 EasySMX ESM-9110 Backplate Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 66
