Salta al contenuto principale
EVGA x17 Disassembly and Cleaning
Cosa ti serve
  1. EVGA x17 Disassembly and Cleaning, Mouse: passo 1, immagine 1 di 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Disassembly and Cleaning: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel
  3. EVGA x17 Disassembly and Cleaning: passo 3, immagine 1 di 1
    • Remove the weight chamber cover and clean with a Q-tip or soft fabric.
  4. EVGA x17 Disassembly and Cleaning: passo 4, immagine 1 di 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
    • Use a Q-tip or soft fabric to clean the bottom panel.
  5. EVGA x17 Disassembly and Cleaning: passo 5, immagine 1 di 1
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Disassembly and Cleaning: passo 6, immagine 1 di 2 EVGA x17 Disassembly and Cleaning: passo 6, immagine 2 di 2
    • Once all screws are removed, carefully slide the middle section out and clean with a Q–tip or soft fabric.
    • Clean the top panel with a Q-tip or soft fabric.
    • Optional: you can remove clickers as well and clean them.
    • Remove the smaller sized cross head screws from the piece labeled A29N001-C V1.0 RU 94V-0. Remove truss head tapping screws from the side of the mouse wheel.
    • Remove 4 screws from the piece labeled AZAC001-A V1.0.
  7. EVGA x17 Disassembly and Cleaning: passo 8, immagine 1 di 1
    • Pull transistor from the side of the mouse wheel.
  8. EVGA x17 Disassembly and Cleaning: passo 9, immagine 1 di 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Disassembly and Cleaning: passo 10, immagine 1 di 2 EVGA x17 Disassembly and Cleaning: passo 10, immagine 2 di 2
    • Remove the scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue.) Clean both with Q-tip or soft fabric.
Conclusione
Melanie
Membro da: 09/11/23
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 96
Tutti i Tempi: 645
