Introduzione
Connection tube and brushbar will need to be removed before replacement. Housing for the brushbar may be damaged and break overtime.
Cosa ti serve
Turn the padlock key counterclockwise using the iFixit Opening Tool.
Pop off the circular plating to remove the housing from the connection piece.
Does anyone know how the wiring loom fits between the grey bit and the clear bit? I took mine apart when cleaning, but cannot figure out how that loom fits; especially the tiny black locating lug. I should have taken photos…
Altre 7 persone hanno completato questa guida.
6 Commenti
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
