Introduzione
Require battery removal, which is not included due to device not having a battery. Connection tubing will need to be removed before motor replacement.
Cosa ti serve
Identify the two white components between the vacuum handle and the attached component.
Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
THis step is not easy! Squeezing the white parts together does release that side of the motor but the other side just will not come out!!
Altre 10 persone hanno completato questa guida.
2 Commenti
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
