Salta al contenuto principale
Dyson V6 Motorhead Motor Replacement
Cosa ti serve
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: passo 1, immagine 1 di 2 Dyson V6 Motorhead Motor Replacement, Collection Bin: passo 1, immagine 2 di 2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: passo 2, immagine 1 di 2 Dyson V6 Motorhead Motor Replacement: passo 2, immagine 2 di 2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: passo 3, immagine 1 di 3 Dyson V6 Motorhead Motor Replacement: passo 3, immagine 2 di 3 Dyson V6 Motorhead Motor Replacement: passo 3, immagine 3 di 3
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: passo 4, immagine 1 di 1
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: passo 5, immagine 1 di 2 Dyson V6 Motorhead Motor Replacement: passo 5, immagine 2 di 2
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: passo 6, immagine 1 di 2 Dyson V6 Motorhead Motor Replacement: passo 6, immagine 2 di 2
    • Detach the motor from the remaining motor head assembly.
Conclusione
Altre 10 persone hanno completato questa guida.
Addie Hedge
Membro da: 01/24/17
710 Reputazione
5 Guide realizzate
Cal Poly, Team 22-6, Maness Winter 2017 Membro di Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Membri
5 Guide realizzate
3Commenti sulla guida
really good can understand and not too technical
kelvin - Replica
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - Replica
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 61
Tutti i Tempi: 19,872
