Salta al contenuto principale
Dyson DC58 Main Body Replacement
Cosa ti serve
Panoramica Video
  1. Dyson DC58 Main Body Replacement, Bin: passo 1, immagine 1 di 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: passo 2, immagine 1 di 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: passo 3, immagine 1 di 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: passo 4, immagine 1 di 2 Dyson DC58 Main Body Replacement: passo 4, immagine 2 di 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: passo 5, immagine 1 di 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: passo 6, immagine 1 di 2 Dyson DC58 Main Body Replacement: passo 6, immagine 2 di 2
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: passo 7, immagine 1 di 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
Conclusione
Altre 12 persone hanno completato questa guida.
Krista St Onge
Membro da: 09/17/15
2.188 Reputazione
2 Guide realizzate
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membri
19 Guide realizzate
4 Commenti
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Replica
Has anyone replaced the red release catch?
chrisashton1 - Replica
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Replica
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 52
Tutti i Tempi: 12,946
