Salta al contenuto principale
Dyson DC58 Main Body Replacement
Cosa ti serve
Panoramica video
    1. Dyson DC58 Main Body Replacement, Bin: passo 1, immagine 1 di 1
      • Make sure your vacuum is unplugged.
      • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dyson DC58 Main Body Replacement: passo 2, immagine 1 di 1
      • Locate the red lever parallel to the red trigger and on the side of the clear bin.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dyson DC58 Main Body Replacement: passo 3, immagine 1 di 1
      • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dyson DC58 Main Body Replacement: passo 4, immagine 1 di 2 Dyson DC58 Main Body Replacement: passo 4, immagine 2 di 2
      • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dyson DC58 Main Body Replacement, Main Body: passo 5, immagine 1 di 1
      • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dyson DC58 Main Body Replacement: passo 6, immagine 1 di 2 Dyson DC58 Main Body Replacement: passo 6, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
      • Use tweezers to pinch the two visible white clips together.
      • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dyson DC58 Main Body Replacement: passo 7, immagine 1 di 1
      • Tilt and pull the main body away from the purple cyclone of the vacuum.
      • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membri
24 guide realizzate
4Commenti sulla guida
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Rispondi Condividi
Has anyone replaced the red release catch?
chrisashton1 - Rispondi Condividi
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Rispondi Condividi
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 63
Tutti i Tempi: 14,648
