Salta al contenuto principale
Dyson DC58 Bin Replacement
  1. Dyson DC58 Bin Replacement, Bin: passo 1, immagine 1 di 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Bin Replacement: passo 2, immagine 1 di 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Bin Replacement: passo 3, immagine 1 di 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Bin Replacement: passo 4, immagine 1 di 2 Dyson DC58 Bin Replacement: passo 4, immagine 2 di 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
Conclusione
Altre 3 persone hanno completato questa guida.
Ian Sloan
Membro da: 09/17/15
161 Reputazione
1 Guida realizzata
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membri
19 Guide realizzate
2 Commenti
The bin is stuck and won’t come off, although I have followed the directions above.
Marcy Altimano - Replica
I think the reassembly instructions should be numbered “Step 5” and printed right below Step 4. They aren’t that easy to see.
Mary Miraglia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 12,825
