Salta al contenuto principale
Dyson DC56 Motor Replacement
Cosa ti serve
  1. Dyson DC56 Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: passo 2, immagine 1 di 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: passo 3, immagine 1 di 1
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: passo 4, immagine 1 di 1
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: passo 5, immagine 1 di 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: passo 6, immagine 1 di 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: passo 7, immagine 1 di 1
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: passo 8, immagine 1 di 1
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: passo 9, immagine 1 di 1
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: passo 10, immagine 1 di 1
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S10-G1, Thompson Fall 2017 Membro di USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,380
