Salta al contenuto principale
Dyson DC56 Battery Replacement
Cosa ti serve
  1. Dyson DC56 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Battery Replacement: passo 3, immagine 1 di 1
    • Separate the device with the purple button.
  4. Dyson DC56 Battery Replacement: passo 4, immagine 1 di 1
    • Take out the filter.
  5. Dyson DC56 Battery Replacement: passo 5, immagine 1 di 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Battery Replacement, Battery screw 2: passo 6, immagine 1 di 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Battery Replacement: passo 7, immagine 1 di 1
    • Pull the battery pack down and away from the main body and remove it from the device.
Conclusione
Altre 9 persone hanno completato questa guida.
Vu Nguyen
Membro da: 10/02/17
189 Reputazione
1 Guida realizzata
USF Tampa, Team S10-G1, Thompson Fall 2017 Membro di USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Membri
11 Guide realizzate
9 Commenti
Works for the DC44 animal also. :)
Tina Willman-Hammar - Replica
You left out the removal of the screw above the charging port.
Mike - Replica
And after unscrewing the 2nd screw, you need very fine tweezers to extract it.
This experience has convinced me never to buy a Dyson product. Their manual gives no info about replacing the battery.
Loohan7 - Replica
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Cliff - Replica
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mark Nicoll - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 108
Tutti i Tempi: 9,961
