Salta al contenuto principale
Dyson DC56 Attachments Replacement
Cosa ti serve
  1. Dyson DC56 Attachments Replacement, Dust Bin: passo 1, immagine 1 di 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Attachments Replacement: passo 2, immagine 1 di 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Attachments Replacement: passo 3, immagine 1 di 1
    • Separate the device with the purple button.
  4. Dyson DC56 Attachments Replacement: passo 4, immagine 1 di 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Attachments Replacement: passo 5, immagine 1 di 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Attachments Replacement: passo 6, immagine 1 di 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Attachments Replacement: passo 7, immagine 1 di 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Attachments Replacement, Attachments: passo 8, immagine 1 di 1
    • Locate two screws at the back of the attachment holder.
  9. Dyson DC56 Attachments Replacement: passo 9, immagine 1 di 1
    • Use a T8-Torque screwdriver to take out the two 26mm screws out.
  10. Dyson DC56 Attachments Replacement: passo 10, immagine 1 di 1
    • Loosen the attachment holder by using a metal spudger.
  11. Dyson DC56 Attachments Replacement: passo 11, immagine 1 di 1
    • Remove the attachment holder.
Conclusione
USF Tampa, Team S10-G1, Thompson Fall 2017 Membro di USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 766
