Salta al contenuto principale
Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: passo 1, immagine 1 di 1
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 2, immagine 1 di 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 2, immagine 2 di 2
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 3, immagine 1 di 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 3, immagine 2 di 2
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 21-4, Maness Winter 2017 Membro di Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,932
