Introduzione
The brush bar on the vacuum can wear with use. If your brush is scratching your floor, or not cleaning as well as it used to, then you may want to replace your brush bar.
Cosa ti serve
Altre 13 persone hanno completato questa guida.
16Commenti sulla guida
RE-insert brush bar? You mean insert new brush bar? (Not reinsert the old one like in the picture because after all this is instructions for replacing the brush bar right?) Aakkk!
At the bottom it says "to reassemble follow these instructions backwards"...something like that.
Excuse me I have to scream now.
Thanks, I got you and I know what you meant. Thanks for taking the time to help others.
