Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
  1. Take off the dust cannister. Remove the suction hose. Remove the suction hose.
    • Take off the dust cannister.
    • Remove the suction hose.
  2. Extract the front filter. Extract the front filter. Extract the front filter.
    • Extract the front filter.
  3. Extract the rear filter. Unscrew the first Torx screw. Unscrew the first Torx screw.
    • Extract the rear filter.
    • Unscrew the first Torx screw.
  4. Optionally, remove the rear filter cover. Optionally, remove the rear filter cover.
    • Optionally, remove the rear filter cover.
  5. Unscrew the 2nd Torx screw. Disassemble the suction hose connection (optional)
    • Unscrew the 2nd Torx screw.
    • Disassemble the suction hose connection (optional)
  6. Remove the wheels. The wheels clip onto the body of the appliance. Unscrew the 4 Torx screws (two in the right and two on the left).
    • Remove the wheels.
    • The wheels clip onto the body of the appliance.
    • Unscrew the 4 Torx screws (two in the right and two on the left).
  7. Open the body of the vacuum cleaner. You can use a multimeter to test the switch.
    • Open the body of the vacuum cleaner.
    • You can use a multimeter to test the switch.
    • Disconnect the brown wire at the switch.
    • Disconnect the blue wire at the single connector by the motor.
    • Lift out the motor.
  8. Open the motor housing (4 clips). Remover the motor from its plastic casing.
    • Open the motor housing (4 clips).
    • Remover the motor from its plastic casing.
    • Disconnect the motor.
  9. disassembly of 2 engine coals (1 Phillips screw per coal) disassembly of 2 engine coals (1 Phillips screw per coal) disassembly of 2 engine coals (1 Phillips screw per coal)
    • disassembly of 2 engine coals (1 Phillips screw per coal)
  10. Worn brush. Opening the brush housing. Opening the brush housing.
    • Worn brush.
    • Opening the brush housing.
  11. Extraction of the brush and spring. Extraction of the brush and spring. Extraction of the brush and spring.
    • Extraction of the brush and spring.
  12. Removing the brush. Removing the brush.
    • Removing the brush.
  13. Soldering a new brush. Soldering a new brush.
    • Soldering a new brush.
Conclusione
Altre 13 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
christophe
Membro da: 14/07/2012
806 Reputazione
2 Guide realizzate
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - Replica
Hi, where did you buy the new motor?
Nadja -
Bravo, très bon tutoriel
shog shog - Replica
Bonjour
et si on n’a rien pour souder, y a t’il une autre solution svp?
GALLAS - Replica
Bonjour ! Si vous ne disposez pas de matérial de soudure, nous vous conseillons de vous rendre à un Repair Café ou un Fab Lab. Ces associations mettent du matériel à disposition et peuvent éventuellement aussi vous conseiller sur la démarche à suivre. Bonne réparation !
Claire Rapp -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 358
Tutti i Tempi: 7,957
