Salta al contenuto principale
Dyson Cinetic Big Ball Animal Upright Hose Replacement
Cosa ti serve
  1. Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: passo 1, immagine 1 di 2 Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: passo 1, immagine 2 di 2
    • Lift off the dust bin from the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 2, immagine 1 di 1
    • Locate the removable hose on the back of the Dyson.
    • Pull up on the hose in order to remove the top half of the hose.
  3. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 3, immagine 1 di 1
    • Locate the red tab on the frontside of Dyson.
  4. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, immagine 1 di 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, immagine 2 di 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, immagine 3 di 3
    • Lift up the red tab with the screwdriver while simultaneously pulling on the back hose.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S13-G1, Banghart Winter 2017 Membro di Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Membri
10 Guide realizzate
2 Commenti
Following step 4, I tried to “lift” the red tab with my screwdriver. It did not budge. After enlarging the photo, I saw that the tab can be seen from both sides. Therefore, I tried “pushing” the red tab instead of “lifting” it, and it popped right off. “Lifting” and “pushing” are different actions.
vlkea01 - Replica
I've taken the small hose out (in the picture, it is in the center at the bottom of the balls) now I cannot get it back in - at one point I thought I had it snapped back in but it didn't stay - any ideas?
K BS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 77
Tutti i Tempi: 11,729
