Introduzione
The Dyson filter is located in the ball-shaped base of the vacuum.
Cosa ti serve
To reassemble your device, follow these instructions in reverse order. The Dyson has two filters, so if the problem has not been resolved, you may have to repeat this process on the other side.
Altre 8 persone hanno completato questa guida.
4 Commenti
Can this filter be washed?
No it's not a washable filter and is supposed to last the life of the machine - hmm… still going to get clogged with fine dust though so yif contact Dyson! They don't last and the increased clogging can reduce the life of the motor.
Scott -
Can you buy a replacement filter?? Thank you.
I’ve bought a second hand dyson big ball cleaner. It’s stinks of dogs. How can I take it apart and clean it?
