Salta al contenuto principale
Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
Cosa ti serve
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: passo 1, immagine 1 di 1
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: passo 2, immagine 1 di 1
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
Conclusione
Allison Turnbaugh
Membro da: 01/25/17
213 Reputazione
2 Guide realizzate
Cal Poly, Team 9-5, Banghart Winter 2017 Membro di Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,431
