Salta al contenuto principale
Dyson Cinetic Animal Ball Motor Replacement
Cosa ti serve
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: passo 1, immagine 1 di 1
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: passo 2, immagine 1 di 1
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: passo 3, immagine 1 di 1
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: passo 4, immagine 1 di 1
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: passo 5, immagine 1 di 1
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
    There is no ifixit screwdriver that could reach some of the T15 screws. so you need a thin long screwdriver to reach some of the screws to remove the cover.
    Rasike Gomes - Replica
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: passo 6, immagine 1 di 1
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, immagine 1 di 2 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, immagine 2 di 2
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    Der Schritt, die Kabel zu durchtrennen, ist überhaupt nicht notwendig! Öffnet man die 3 “Plastikschnallen” des Motorgehäuses, findet man sowohl für das weiße als auch für das schwarze Kabel einen kleinen Stecker, der ganz leicht gelöst werden kann. Dementsprechend erübrigt sich das Verlöten und die damit verbundene komplizierte Arbeit. Einfach den alten Motor aus dem Gehäuse nehmen, den neuen einsetzen und die beiden Kabel auf die Steckverbindungen schieben, das war’s.
    Marlies Thoennissen - Replica
    Inutile de couper les fils. Ouvrir le boitier contenant le moteur pour constater que celui-ci est connecté avec des cosses plates, il suffit tout simplement de les débrancher.
    JC JOLY - 11 nov 2023
    JEAN CLAUDE JOLY - Replica
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 9-5, Banghart Winter 2017 Membro di Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Membri
18 Guide realizzate
4 Commenti
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Replica
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Replica
great instructions, dismantled perfectly.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 242
Tutti i Tempi: 21,600
