Salta al contenuto principale
Dyson Cinetic Animal Ball Motor Replacement
Cosa ti serve
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: passo 1, immagine 1 di 1
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: passo 2, immagine 1 di 1
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: passo 3, immagine 1 di 1
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: passo 4, immagine 1 di 1
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: passo 5, immagine 1 di 1
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: passo 6, immagine 1 di 1
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, immagine 1 di 2 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, immagine 2 di 2
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 9-5, Banghart Winter 2017 Membro di Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
3 Membri
18 Guide realizzate
4 Commenti
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Replica
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Replica
great instructions, dismantled perfectly.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 229
Tutti i Tempi: 22,216
