Salta al contenuto principale
Dyson Ball Animal Power Cord Replacement
Cosa ti serve
  1. Dyson Ball Animal Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Turn off and unplug the vacuum.
    • Remove the vacuum canister from the front of the vacuum.
  2. Dyson Ball Animal Power Cord Replacement: passo 2, immagine 1 di 1
    • Flip the vacuum around and remove the hose so it is not blocking the back of the vacuum.
  3. Dyson Ball Animal Power Cord Replacement: passo 3, immagine 1 di 3 Dyson Ball Animal Power Cord Replacement: passo 3, immagine 2 di 3 Dyson Ball Animal Power Cord Replacement: passo 3, immagine 3 di 3
    • There are four 15mm screws that must be removed with a Torx T15 screwdriver.
  4. Dyson Ball Animal Power Cord Replacement: passo 4, immagine 1 di 3 Dyson Ball Animal Power Cord Replacement: passo 4, immagine 2 di 3 Dyson Ball Animal Power Cord Replacement: passo 4, immagine 3 di 3
    • After all the screws are released there are two tabs that must be pressed in and towards the center.
    • The tabs can be pressed in one at a time but may require some force.
  5. Dyson Ball Animal Power Cord Replacement: passo 5, immagine 1 di 2 Dyson Ball Animal Power Cord Replacement: passo 5, immagine 2 di 2
    • After removing the two tabs gently pull the face off the power supply.
  6. Dyson Ball Animal Power Cord Replacement: passo 6, immagine 1 di 1
    • Follow the black cord from the power cord.
    • Pinch the plastic piece.
    • Remove from the metal tongue.
    • When removing the cords, grab them from the plastic parts and not the cord.
  7. Dyson Ball Animal Power Cord Replacement: passo 7, immagine 1 di 3 Dyson Ball Animal Power Cord Replacement: passo 7, immagine 2 di 3 Dyson Ball Animal Power Cord Replacement: passo 7, immagine 3 di 3
    • There is also a black case that needs to be opened in order to remove the power cord.
    • After opening the case pull apart the wire and attach the new wire.
    • Again, make sure that you are pulling from the heads of the wires and not the wires themselves.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S15-G5, Banghart Spring 2017 Membro di Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Membri
17 Guide realizzate
3 Commenti
Great tutorial! The pictures were awesome, I replaced my cord in about 15 minutes thanks to this post. The only thing you might want to add is the gray switch with the spring. Mine fell out while I was trying to put the unit back together and I had to research how it went back together correctly. Thanks again!
Jim
Jim Knox - Replica
I had the same spring lever issue. This video shows how to replace them.
https://youtu.be/CLk1Zu6nREk
Robert W Marvin - Replica
Thank you for the YouTube link on the button reassembly. I should have expected it to be sitting loaded when I disassembled it.
chuckparent -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 190
Tutti i Tempi: 36,022
