Salta al contenuto principale
Dyson Ball Animal Power Button Replacement
Cosa ti serve
  1. Dyson Ball Animal Power Button Replacement, Power Button: passo 1, immagine 1 di 2 Dyson Ball Animal Power Button Replacement, Power Button: passo 1, immagine 2 di 2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: passo 2, immagine 1 di 1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: passo 3, immagine 1 di 2 Dyson Ball Animal Power Button Replacement: passo 3, immagine 2 di 2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: passo 4, immagine 1 di 2 Dyson Ball Animal Power Button Replacement: passo 4, immagine 2 di 2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: passo 5, immagine 1 di 3 Dyson Ball Animal Power Button Replacement: passo 5, immagine 2 di 3 Dyson Ball Animal Power Button Replacement: passo 5, immagine 3 di 3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: passo 6, immagine 1 di 2 Dyson Ball Animal Power Button Replacement: passo 6, immagine 2 di 2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: passo 7, immagine 1 di 2 Dyson Ball Animal Power Button Replacement: passo 7, immagine 2 di 2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
Conclusione
Altre 4 persone hanno completato questa guida.
Hank Wai
Membro da: 05/07/17
166 Reputazione
1 Guida realizzata
Cal Poly, Team S15-G5, Banghart Spring 2017 Membro di Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 52
Tutti i Tempi: 6,796
