Introduzione
The WiFi antenna is found on the back left of the device. It is black and extends an inch outside of the device. This guide will take you through the steps of removing the cover and antenna. The antenna must be removed to perform maintenance on the motherboard of this device.
Strumenti
Parti
Nessuna parte specificata.
Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
Altre 3 persone hanno completato questa guida.
