Salta al contenuto principale
Introduzione
The power board is found adjacent to the motherboard inside the device. This guide will take you through the steps of removing the powerboard for replacement.
Parti
Nessuna parte specificata.
  1. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
    • Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
  2. Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Remove the 9-pin white wire connecting the power board to the mother board. Remove the 9-pin white wire connecting the power board to the mother board.
    • Remove the 9-pin white wire connecting the power board to the mother board.
  6. Remove the front of the device  by removing the two screws, holding it the the body of the device. Make sure to place the grounding wire between the screw and the device when reassembling.
    • Remove the front of the device by removing the two screws, holding it the the body of the device.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  7. Remove the 4 screws holding the power board the the body of the device. Remember to connect the grounding wire to the screw next to the front panel and optical drive when reassembling.
    • Remove the 4 screws holding the power board the the body of the device.
    • Remember to connect the grounding wire to the screw next to the front panel and optical drive when reassembling.
  8. Remove the white clip. Remove the white clip.
    • Remove the white clip.
  9. Remove the power supply board.
    • Remove the power supply board.
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 161
