Introduzione
The discdrive is found next to the motherboard and power board inside the device. This guide will take you through the steps of removing the discdrive for replacement.
  1. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
    • Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
  2. Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Check that the power cord is not preventing the device from opening or closing.
  5. Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive. Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  6. Detach the tape wires from the motherboard and power board. Detach the tape wires from the motherboard and power board.
    • Detach the tape wires from the motherboard and power board.
  7. Lift the disc drive up to a 45 degree angle and pull back out of the device shell Lift the disc drive up to a 45 degree angle and pull back out of the device shell
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 99
