Salta al contenuto principale
Dynex DX-WBRDVD1 Cleaning The Optical Lens
Cosa ti serve
  1. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: passo 1, immagine 1 di 2 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: passo 1, immagine 2 di 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 2, immagine 1 di 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 3, immagine 1 di 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 4, immagine 1 di 2 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 4, immagine 2 di 2
    • To access the optical lens, pull back the optical drive as shown in the pictures located on the two metal rails.
  5. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 5, immagine 1 di 2 Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 583
