Introduzione
If your Durofix RV332 cordless driver has stopped turning or is struggling to deliver the torque it used to, it’s quite likely that the internal motor assembly has worn out or failed altogether.
This step‑by‑step repair will show you how to remove the old motor and install a replacement, restoring your tool’s full functionality.
Before you dive in, you’ll want to ensure you have a clean, well‑lit workspace.
This repair requires soldering. If you're not familiar with soldering or need a refresher, the guide, How to Solder and Desolder Connectors, is a helpful reference. The soldering iron gets extremely hot and can easily burn your skin so be careful when using it. Because you’ll be working inside a live cordless tool, it’s essential to remove the battery or isolate power first (to prevent accidental activation), and to take care when handling internal wiring and printed circuit board (PCB) components to avoid short‑circuits or damage.
Once the new motor is reinstalled, test the driver, and assuming everything’s gone according to plan, your RV332 will be back to delivering the rotation force it had when new. With patience and attention to detail, this motor swap is a practical way to revive a cordless driver rather than replace the entire unit.
Part# 3805-30529
Cosa ti serve
Use the Phillips #0 screwdriver to remove six 13 mm screws from the casing.
Place the motor, along with the PCB, LED, and battery, back into the plastic housing in the correct orientation.
Close the casing halves together, ensuring clips and alignment are correct.
Reinsert and tighten the six screws you removed earlier.
Finally, test the device to confirm the motor now works.
If everything functions, you're done. If not, reopen and re-check your soldering and connections.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
1Commento della guida
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
