Salta al contenuto principale
Durofix RV332 Battery Replacement
Cosa ti serve
  1. Durofix RV332 Battery Replacement, Battery: passo 1, immagine 1 di 3 Durofix RV332 Battery Replacement, Battery: passo 1, immagine 2 di 3 Durofix RV332 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: passo 2, immagine 1 di 2 Durofix RV332 Battery Replacement: passo 2, immagine 2 di 2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: passo 3, immagine 1 di 1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
Conclusione
Altre 3 persone hanno completato questa guida.
Brennan Wade
Membro da: 02/21/14
130 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 56
Tutti i Tempi: 3,250
