Introduzione
Your Dualshock 4 D-pad can wear out after continuous use. This happens because the silicone rubber underneath the D-pad begins to break, causing your controller to think you're holding a direction when you are not (drift). It can also make the D-pad a lot harder to use. This guide demonstrates how to safely open a Dualshock 4 CUH-ZCT2U controller and replace the silicone conductive rubber contact pad or gasket.
Cosa ti serve
Use a Phillips #00 screwdriver to remove the four 6.0 mm-long screws on the back of the controller.
Altre 2 persone hanno completato questa guida.
