Salta al contenuto principale
DualShock 4 CHU-ZCT2U Front Panel Replacement
Cosa ti serve
  1. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the rear panel screws: passo 1, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the rear panel screws: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Front Panel Replacement, Separate the rear panel: passo 2, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Separate the rear panel: passo 2, immagine 2 di 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Front Panel Replacement, Release the plastic clips: passo 3, immagine 1 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Release the plastic clips: passo 3, immagine 2 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Release the plastic clips: passo 3, immagine 3 di 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the rear panel: passo 4, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the rear panel: passo 4, immagine 2 di 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 5, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 5, immagine 2 di 2
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the battery: passo 6, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the battery: passo 6, immagine 2 di 2
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 7, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 7, immagine 2 di 2
    • Remove the battery.
  8. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the motherboard: passo 8, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the motherboard: passo 8, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 9, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 9, immagine 2 di 2
    • Remove the battery bracket.
  10. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 10, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 10, immagine 2 di 2
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 11, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 11, immagine 2 di 2
    • Separate the motherboard and midframe assembly from the front panel.
  12. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the touchpad: passo 12, immagine 1 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the touchpad: passo 12, immagine 2 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the touchpad: passo 12, immagine 3 di 3
    • Push the bottom of the touchpad in from the front side of the controller to separate it from the front case.
    • Remove the touchpad from the bezel holding it to the front case.
  13. DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the buttons: passo 13, immagine 1 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the buttons: passo 13, immagine 2 di 3 DualShock 4 CHU-ZCT2U Front Panel Replacement, Remove the buttons: passo 13, immagine 3 di 3
    • Use your fingers or a pair of tweezers to remove the three silicone conductive rubber pads from the controller buttons.
  14. DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 14, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement: passo 14, immagine 2 di 2
    • Slowly turn over the front panel to let the buttons fall out.
    • Only the front panel remains.
    • The round buttons have unique notches designed to prevent them from being installed incorrectly.
  15. DualShock 4 CHU-ZCT2U Front Panel Replacement, Reassembly tip: passo 15, immagine 1 di 2 DualShock 4 CHU-ZCT2U Front Panel Replacement, Reassembly tip: passo 15, immagine 2 di 2
    • During reassembly, use your fingers or a pair of tweezers to drop the buttons into their respective holes on the front panel.
    • Align the button notches to ensure each one is fully inserted and in the correct location.
Conclusione
Altre 3 persone hanno completato questa guida.
Sam Omiotek
Membro da: 02/25/19
72.595 Reputazione
288 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 92
Tutti i Tempi: 3,492
