Salta al contenuto principale
DualShock 4 CHU-ZCT2U Charging Port Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, immagine 1 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, immagine 2 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, immagine 3 di 3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
    When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
    Tale Spinner - Replica
    This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
    Ville Närhi - Replica
    Your advice for opening shell was so bad and harmful.
    It's not correct
    Kiarash Moallemi - Replica
    And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
    Strings Cat - Replica
    I've written a guide for how to find and unlatch the clips
    Important Step For Opening the DualShock 4 CUH-ZCT2U
    Richard - Replica
  2. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, immagine 1 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, immagine 2 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, immagine 3 di 3
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
    If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
  3. DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: passo 3, immagine 1 di 2 DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: passo 3, immagine 2 di 2
    • Pull the ribbon cable from the charge port, using a set of tweezers.
  4. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, immagine 1 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, immagine 2 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, immagine 3 di 3
    • Grip the right hand corner of the opaque white piece with a pair of tweezers, and pull it upwards to remove it.
    Müssten heißen: “Fasse die rechte Ecke des WEISSEN Plastikteils …”
    Wolfgang Brandner - Replica
  5. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, immagine 1 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, immagine 2 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, immagine 3 di 3
    • Lift the clear plastic piece up by its right hand corner.
    • Pull it to the right to remove the bottom left hand corner from the groove.
    • Remove the clear plastic piece. It pushes in easily.
  6. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, immagine 1 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, immagine 2 di 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, immagine 3 di 3
    • Peel off the black sticker on the charge port, using a pair of tweezers.
    • Unscrew the 4.50mm screw in the center of the port chip, using a Phillips-Head screwdriver.
    • Pull the charging port out with a pair of tweezers.
Conclusione
Altre 16 persone hanno completato questa guida.
David Seale
Membro da: 10/09/17
1.630 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G5, Leahy Fall 2017 Membro di USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 Membri
22 Guide realizzate
9 Commenti
Came in handy, since it’s hard enough to fix a JDM-030. Thanks!
Sunset Shimmer - Replica
Just did this on my JDM-030 (3rd generation DS4) as well. I would point out that the charge port for the JDM-030 (JDS-030?) looks slightly different and has more of a T-shape than the JDS-040, but aside from that, the instructions are functionally the same.
I will lastly add that having good tweezers is a must: the tweezers my jeweler’s drivers came with were crap and I had to go to the store to buy another pair. Make sure your equipment is solid before assembly.
Rob Barba - Replica
Can The JDS 040 work in a controller that uses the JDS 030?
RandyH - Replica
Tried to replace my usb port with a board that reads “1-981-33-31” from amazon. It was listed as JDS-40 and it does not work. In fact when plugged into a usb port on my laptop the ribbon cable gets noticeably hot but the controller will not power on.
Devin Sidell - Replica
Got the same problem. Any idea?
Jacco Veldscholten -
only wish we could change port to USB-C that would be awesome but impossible i think
DARKMATTER - Replica
Has anyone tried fixing the analog joystick on the new jds-055 I have fixed all other generations but this is the only one that I cant fix
SAM CORTEZ - Replica
Will the JDS-055 work with the JDS-050?
aaron boschman - Replica
where can i find a JDM-055
low bros - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 13,159
