Parti
Nessuna parte specificata.
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
Pry the two halves of the shell apart using a plastic opening tool.
Unplug the black and red wires from the power port located on the motherboard.
Remove the old battery from the controller.
Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
Altre 30 persone hanno completato questa guida.
