Salta al contenuto principale
Sostituzione copertura posteriore DualShock 3
Cosa ti serve
  1. Sostituzione copertura posteriore DualShock 3, Copertura posteriore: passo 1, immagine 1 di 1
    • Svita le cinque viti a croce Phillips da 7,2 mm che tengono ferma la copertura posteriore.
    I have 2 controllers I'd like to fix, and both have at least one stripped screw in them. Any tips for removing them?
    Joe - Replica
  2. Sostituzione copertura posteriore DualShock 3: passo 2, immagine 1 di 1
    • Premi la copertura posteriore tra gli stick analogici e solleva leggermente il bordo inferiore dal controller.
    Es ist nicht ganz eindeutig das zwischen den beiden Analog-Sticks gedrückt werden muss. Der gelbe Punkt fällt kaum auf. Ein Bild mit Daumen an dieser Stelle wäre gut oder soooo…
    Tom - Replica
    it’s not very clear but for this step you need to push where the yellow dot is shown on the picture. it’s rather tough. you kind of have to move the whole back plate a bit for it to work.
    Brandon der Blatter - Replica
    I’m stuck at this step because I can’t for the life of me undo the clip
    IttyBittyGamerVR - Replica
    Yeah I’m lost here too. I’m pushing where the dot is but nothing is happening. What am I trying to accomplish by pushing there? Is there a clasp on the inside I’m trying to undo or something? I really don’t want to break the controller by using too much force or opening it the wrong way.
    Could it be that the sixaxis I have is constructed differently? Or is this just a difficult step?
    Joe - Replica
    Adding: I ended up getting the shell off but ended up breaking off a small piece which I'm guessing was securing the front and back shells together. The trigger buttons and pieces remained intact on one of my two controllers which is what I was worried about, though I did have to fit the small trigger pieces back in.
    The one controller seemed to fit back together just fine without the small piece that broke off, and buttons seemed to feel and work fine too.
    Joe -
    I had to use a small flathead to lever it apart.
    mbelanger - Replica
  3. Sostituzione copertura posteriore DualShock 3: passo 3, immagine 1 di 2 Sostituzione copertura posteriore DualShock 3: passo 3, immagine 2 di 2
    • Spingi leggermente la copertura posteriore verso il bordo superiore del controller per superare i grilletti R2 e L2.
    • Tira via la copertura posteriore dal resto del controller, stando attento a non far saltare i 2 grilletti.
    • Se per sbaglio i grilletti vengono rimossi, abbiamo una guida per riattaccarli.
    the "trigger button guide" link links back to this page :o
    Alexander McMahon - Replica
    I accidentally popped a trigger off, and both L1 and R1, because I skimmed and didn't read this step. Fortunately it's not hard. The tricky part with the triggers is that there's a little spring on them. You have to press the side of the spring that's pointing away from the trigger against the sloped surface of the controller (look at the other trigger for reference, if you only popped one off). Then you just slide the trigger on until the "handlebar" bits near the center click into place.
    briancaraher - Replica
    The reset button – a small mostly-rectangular rubberized piece – fell out as I removed the rear cover. It covers the hole near the middle screw and has a post that presses SW1 on the motherboard.
    Fletcher Stern - Replica
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 24 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
3 Commenti
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - Replica
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost -
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 69
Tutti i Tempi: 23,763
