Salta al contenuto principale
DualShock 3 Front Shell Cover Replacement
Cosa ti serve
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: passo 1, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: passo 1, immagine 2 di 2
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
  2. DualShock 3 Front Shell Cover Replacement: passo 2, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 2, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
  3. DualShock 3 Front Shell Cover Replacement: passo 3, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement: passo 3, immagine 2 di 2
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
  4. DualShock 3 Front Shell Cover Replacement: passo 4, immagine 1 di 1
    • Lift the rear cover off of the controller to expose the interior.
  5. DualShock 3 Front Shell Cover Replacement: passo 5, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 5, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 5, immagine 3 di 3
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
  6. DualShock 3 Front Shell Cover Replacement: passo 6, immagine 1 di 3 DualShock 3 Front Shell Cover Replacement: passo 6, immagine 2 di 3 DualShock 3 Front Shell Cover Replacement: passo 6, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
  7. DualShock 3 Front Shell Cover Replacement: passo 7, immagine 1 di 2 DualShock 3 Front Shell Cover Replacement: passo 7, immagine 2 di 2
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
  8. DualShock 3 Front Shell Cover Replacement: passo 8, immagine 1 di 1
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
Conclusione
Altre 4 persone hanno completato questa guida.
Joseph Wambui
Membro da: 07/09/21
253 Reputazione
1 Guida realizzata
2Commenti sulla guida
Personally I believe with the current price of a DualShock 3 controller its not even worth it to replace the following parts. Or maybe its just me? Sony has done a great product and will continue to do so!
Andrew McMason - Replica
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 146
Tutti i Tempi: 6,246
