Salta al contenuto principale
Droid Ultra XT1080 Power Button Replacement
Cosa ti serve
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: passo 2, immagine 1 di 1
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: passo 4, immagine 1 di 2 Droid Ultra XT1080 Power Button Replacement: passo 4, immagine 2 di 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: passo 5, immagine 1 di 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: passo 6, immagine 1 di 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: passo 7, immagine 1 di 2 Droid Ultra XT1080 Power Button Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
Conclusione
knoyes
Membro da: 10/30/18
785 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 301
