Salta al contenuto principale
Droid Ultra XT1080 Charging Port Replacement
Cosa ti serve
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: passo 1, immagine 1 di 1
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: passo 2, immagine 1 di 1
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: passo 3, immagine 1 di 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: passo 4, immagine 1 di 2 Droid Ultra XT1080 Charging Port  Replacement: passo 4, immagine 2 di 2
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: passo 5, immagine 1 di 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: passo 6, immagine 1 di 1
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: passo 7, immagine 1 di 2 Droid Ultra XT1080 Charging Port  Replacement: passo 7, immagine 2 di 2
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: passo 8, immagine 1 di 1
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Conclusione
knoyes
Membro da: 10/30/18
785 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 860
