Salta al contenuto principale
Droid Ultra XT1080 Battery Replacement
Cosa ti serve
  1. Droid Ultra XT1080 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: passo 2, immagine 1 di 1
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: passo 4, immagine 1 di 2 Droid Ultra XT1080 Battery Replacement: passo 4, immagine 2 di 2
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: passo 5, immagine 1 di 1
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: passo 7, immagine 1 di 2 Droid Ultra XT1080 Battery Replacement: passo 7, immagine 2 di 2
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: passo 8, immagine 1 di 1
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
Conclusione
Altre 3 persone hanno completato questa guida.
knoyes
Membro da: 10/30/18
785 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,984
