Salta al contenuto principale
Drobo FS DRDS2-A Power Switch Replacement
Cosa ti serve
  1. Drobo FS DRDS2-A Power Switch Replacement, Case: passo 1, immagine 1 di 1
    • To start getting the case off remove the front panel so it's out of the way.
  2. Drobo FS DRDS2-A Power Switch Replacement: passo 2, immagine 1 di 2 Drobo FS DRDS2-A Power Switch Replacement: passo 2, immagine 2 di 2
    • Next remove the screws from the feet of the case with a phillips head screwdriver.
  3. Drobo FS DRDS2-A Power Switch Replacement: passo 3, immagine 1 di 1
    • To remove the case, place the Drobo on its back and slide the case off.
  4. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, immagine 1 di 3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, immagine 2 di 3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, immagine 3 di 3
    • Press tabs to release back cover and lift off
  5. Drobo FS DRDS2-A Power Switch Replacement: passo 5, immagine 1 di 2 Drobo FS DRDS2-A Power Switch Replacement: passo 5, immagine 2 di 2
    • Push tabs in and carefully pull out the front facer and drive shelves
  6. Drobo FS DRDS2-A Power Switch Replacement: passo 6, immagine 1 di 2 Drobo FS DRDS2-A Power Switch Replacement: passo 6, immagine 2 di 2
    • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
    • If you have a Drobo 5N2, you may also need to remove the 3 screws on each side.
  7. Drobo FS DRDS2-A Power Switch Replacement: passo 7, immagine 1 di 2 Drobo FS DRDS2-A Power Switch Replacement: passo 7, immagine 2 di 2
    • Carefully unplug the Power Switch and Fan wires.
  8. Drobo FS DRDS2-A Power Switch Replacement: passo 8, immagine 1 di 1
    • Press tabs on Power Switch to release the Power Switch and Push out.
    • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
  9. Drobo FS DRDS2-A Power Switch Replacement: passo 9, immagine 1 di 2 Drobo FS DRDS2-A Power Switch Replacement: passo 9, immagine 2 di 2
    • Finally pull the old switch out and pop the new one in.
Conclusione
Altre 2 persone hanno completato questa guida.
Rye Cassan
Membro da: 01/24/17
155 Reputazione
1 Guida realizzata
Cal Poly, Team 10-4, Banghart Winter 2017 Membro di Cal Poly, Team 10-4, Banghart Winter 2017
CPSU-BANGHART-W17S10G4
3 Membri
5 Guide realizzate
4 Commenti
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - Replica
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - Replica
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - Replica
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
John W - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 38
Tutti i Tempi: 2,114
