Salta al contenuto principale
Drill Master Heat Gun Motor Replacement
Cosa ti serve
  1. Drill Master Heat Gun Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Motor Replacement: passo 2, immagine 1 di 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Motor Replacement: passo 3, immagine 1 di 3 Drill Master Heat Gun Motor Replacement: passo 3, immagine 2 di 3 Drill Master Heat Gun Motor Replacement: passo 3, immagine 3 di 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Motor Replacement: passo 4, immagine 1 di 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Motor Replacement: passo 5, immagine 1 di 1
    • Remove the metal casing and fan cover from the fan unit.
  6. Drill Master Heat Gun Motor Replacement: passo 6, immagine 1 di 1
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
  7. Drill Master Heat Gun Motor Replacement: passo 7, immagine 1 di 1
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
  8. Drill Master Heat Gun Motor Replacement: passo 8, immagine 1 di 1
    • Remove the fan by pulling it from the motor rod.
  9. Drill Master Heat Gun Motor Replacement: passo 9, immagine 1 di 1
    • Remove the two 12mm screws from the plastic fan casing using PH#00
  10. Drill Master Heat Gun Motor Replacement: passo 10, immagine 1 di 1
    • Remove the plastic fan casing.
  11. Drill Master Heat Gun Motor Replacement: passo 11, immagine 1 di 1
    • Remove the metal casing from the motor and insert the new motor in its place.
    • You may have to tug a little.
Conclusione
Un commento
Where can I find a new motor?
jstabler38 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,446
