Salta al contenuto principale
Drill Master Heat Gun Heating Coil Replacement
Cosa ti serve
  1. Drill Master Heat Gun Heating Coil Replacement, Heating Coil: passo 1, immagine 1 di 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Heating Coil Replacement: passo 2, immagine 1 di 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Heating Coil Replacement: passo 3, immagine 1 di 3 Drill Master Heat Gun Heating Coil Replacement: passo 3, immagine 2 di 3 Drill Master Heat Gun Heating Coil Replacement: passo 3, immagine 3 di 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Heating Coil Replacement: passo 4, immagine 1 di 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Heating Coil Replacement: passo 5, immagine 1 di 1
    • Remove the plastic casing from the end of the barrel.
  6. Drill Master Heat Gun Heating Coil Replacement: passo 6, immagine 1 di 1
    • Remove the metal casing from the heating element.
  7. Drill Master Heat Gun Heating Coil Replacement: passo 7, immagine 1 di 1
    • Slowly remove the heat resistant wrapping from the heating element.
    • Be careful here - the wrapping can be easily torn!
  8. Drill Master Heat Gun Heating Coil Replacement: passo 8, immagine 1 di 2 Drill Master Heat Gun Heating Coil Replacement: passo 8, immagine 2 di 2
    • Use the angled tweezers to remove the heating coil end from the input point.
  9. Drill Master Heat Gun Heating Coil Replacement: passo 9, immagine 1 di 1
    • Remove the heating coil by unraveling it from the heating element.
    • To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
Where are the heating coil wires found?
Thomas Frye - Replica
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 4,098
