Salta al contenuto principale
Drift HD 720 Speaker Replacement
Cosa ti serve
  1. Drift HD 720 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Drift HD 720 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Speaker Replacement: passo 2, immagine 1 di 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the back case from the camera body.
  5. Drift HD 720 Speaker Replacement: passo 5, immagine 1 di 1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the wires connecting the speaker to the motherboard from the motherboard, and solder the wires connecting the new speaker to the motherboard in the same locations as the wires that were removed.
Conclusione
Baylor, Team 10-16, Williams Fall 2015 Membro di Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 206
